When I try to compile s function, I got an error.
Error using mex
C:\Users\Aman\AppData\Local\Temp\mex_144915910790007_18676\FAST_SFunc.obj:FAST_SFunc.c:(.text+0x1183): undefined reference to
`min’
collect2.exe: error: ld returned 1 exit status
Error in create_FAST_SFunc (line 7)
mex -v -L…/…/bin -lFAST_Library_x64 …
Dear @Aman.Ali ,
I’m not familiar with that error. Which version of FAST or OpenFAST are you trying to compile?
Dear @Jason.Jonkman
I am using FAST_v8.16.00a-bjj version.
Dear @Aman.Ali,
Are you not able to use the precompiled S-Function for FAST v8.16 that is provided with the archive, e.g., because you’ve changed the source code or have an operating system other than Windows?
Dear @Jason.Jonkman
I didn’t change anything in the source file. I just want to run sample file Run_OpenLoop.m, but I got the error.
Error reported by S-function ‘FAST_SFunc’ in ‘OpenLoop/FAST Nonlinear Wind Turbine/S-Function’:
Dear @Aman.Ali,
Can you share the full message from the MATLAB workspace when you try to run the sample file Run_OpenLoop.m? In your related post (problem with FAST on MATLAb/Simulink - #14 by Jason.Jonkman), it sounded like your problem was regarding the use of 32-bit controller with a 64-bit version of Simulink.
