Hi friends,
I was trying to understand the relation between nominal tip speed and nominal rotational speed.
Is it such that nominal tip speed = nominal rotational speed * blade radius?
Thanks in advance for reply!
Hi friends,
I’m not sure what you mean by “nominal”, but for a rigid rotor, the tip speed is equal to the rotor speed (in rad/s) times the perpendicular distance from the tip to the axis of rotation (this accounts for precone).
