I have been trying to get Sectional Motions (e.g. N2TDxr) from BeamDyn, FAST runs without a problem but, as outputs TDxrs are “INVALID” and are all equal to zero. I dont understand if I am providing fast with Invalid inputs or BeamDyn is not successfully calculating those motions.
I came across some similar problems in the forum and saw dr. Jonkman recommend Openfast on github, I also gave that a try and got the same results.
I appreciate your guidance.
farhad
ps: In the attached photo I put any changes that I did to the default FAST files in a red circle.
Dear Farhad,
BeamDyn is not outputting the nodal motions because you’ve set NNodeOuts = 0. From your BeamDyn input file, I see that your BeamDyn model has 6 nodes, so, you can set NNodeOuts as high as 6. Also, if you want the tip motions output, change “N9” to “N6” in the output names in your OutList.
Thank you dr. Jonkman for quick response, It is working now.
I understand that section 1-9 and tip are available as outputs. Is there a way to get results for rest of the sections? for example NREL 5WM-Baseline has 49 sections, can BeamDyn calculate behavior of 10-48 sections?
Dear Farhad,
The nodal outputs are available for the finite-element nodes, not for the sectional input stations used to define the blade mass and stiffness distribution. If you wish to have more than 6 output nodes, you’ll have to increase the order of the finite element.
Thank you dr. I think I understand now.
