Hi
I have run the FAST simulation for Test18 (NREL 5 MW land based 63 m turbine). I want to use the output loads and moments into an FEA tool. We have below output from FAST for the spanwise loads
Spn1MLxb1 to Spn5MLxb1 (local edgewise moments for station 1 to 5)
Spn1MLyb1 to Spn5MLyb1 (local flapwise moments for station 1 to 5)
Spn1MLzb1 to Spn5MLzb1 (local pitching moments for station 1 to 5)
Query 1: Where are these stations located along the 61.5 m blade span?. Is there any fig/table showing the coordinates to apply these forces?
Query 2: In general is there a guidance on carrying below parameters from FAST run to commercial FEA tools like Ansys/Abaqus?
RootFxc1,RootFyc1,RootFzc1 out-of-plane shear, in-plane shear and axial force at blade-1 root
RootFxc2,RootFyc2,RootFzc2 out-of-plane shear, in-plane shear and axial force at blade-2 root
RootFxc3,RootFyc3,RootFzc3 out-of-plane shear, in-plane shear and axial force at blade-3 root
RootMxc1,RootMyc1,RootMzc1 in-plane moment, out-of-plane moment and pitching moment at blade-1 root
RootMxc2,RootMyc2,RootMzc2 in-plane moment, out-of-plane moment and pitching moment at blade-1 root
RootMxc3,RootMyc3,RootMzc3 in-plane moment, out-of-plane moment and pitching moment at blade-1 root
RootMxb1, RootMyb1 - Blade 1 edgewise and flapwise moments at root
RootMxb2, RootMyb2 - Blade 2 edgewise and flapwise moments at root
RootMxb3, RootMyb3 - Blade 3 edgewise and flapwise moments at root
-Best Regards
Pravin
