I am trying to modify the Structural Control module to simulate a structural control method similar to a tuned mass damper, but it includes an additional mass and spring constant that I am trying to add to the code. However, when I try to add these values (I have adjusted the size of u%CmdStiff to accommodate this fourth stiffness parameter), I get this error for the mass and stiffness values. I already added these parameters to the code based on how the other stiffness and mass values are defined, and I added these values to the StrcCtrl_Registry.txt file (K_b and M_b are the stiffness and mass values, respectivley.
Is there somewhere else that I still need to modify the code to allow me to use these parameters or is there something that I am missing?
