About unit when calculating control gain(Kp and KI)
Dear Jason.
I have two questions about the unit.
First, I am calculating the gain value in blade pitch control using below equation.
Kp=(2*(Drivetrain Inertia)(rated low-speed shaft rotational speed)(damping ration)(natural frequency))/(Gearbox ratio-Sensitivity Power to Pitch)
Could you let me know the exact unit of rated low-speed shaft rotational speed in the above equation? (either rpm or rad/sec)
Second, I got the power sensitivity to blade pitch as below from FAST linearization.
I got the sensitivity -7.485E+03 from D-Trnsmt Matrix. Then what is the exact unit for the sensitivity? (either kw/deg or kw/rad)
Order of Control Inputs in Linearized State Matrices:
Column 1 = rotor collective blade pitch (rad) 4.62861E-02 op
Order of Input Wind Disturbances in Linearized State Matrices:
None selected
Order of Output Measurements in Linearized State Matrices:
Row 1 = WindVxi (m/sec)
Row 2 = RotPwr (kW)
Row 3 = GenPwr (kW)
Row 4 = BldPitch1 (deg)
Row 5 = RotSpeed (rpm)
Row 6 = GenSpeed (rpm)
Row 7 = GenTq (kN-m)
--------- Azimuth = 0.00 deg (with respect to AzimB1Up = 0.00 deg) ---------
op State | op | A - State | B - Input
Derivativs | States | Matrix | Matrix
0.000E+00 | 0.000E+00 | 0.000E+00 1.000E+00 | 0.000E+00
0.000E+00 | 0.000E+00 | -1.093E+03 -3.832E+00 | -9.485E-02
op Output | This colmn | C - Output | D - Trnsmt
Measurmnts | is blank | Matrix | Matrix
1.200E+01 | | 0.000E+00 0.000E+00 | 0.000E+00
3.335E+03 | | -1.892E+06 -6.723E+03 | -7.485E+03
0.000E+00 | | 0.000E+00 0.000E+00 | 0.000E+00
2.652E+00 | | 0.000E+00 0.000E+00 | 5.730E+01
1.700E+01 | | 0.000E+00 0.000E+00 | 0.000E+00
1.530E+03 | | 0.000E+00 0.000E+00 | 0.000E+00
Thank you.
HyoungChul Kim.
Dear HyoungChul Kim,
The units in your equation for Kp should be consistent e.g. kg, m, s, N, rad. The rotational speed should be in rad/s.
The units are given in the linearization output file:
That is, the blade-pitch input is in rad and the output RotPwr is in kW, so, -7.485E+03 has the units of kW/rad.
Dear Jason.
Thank you for your help.
Sincerely,
Daniel Kim
