Dear everyone,
I’m trying to calculate the 1st Fore-Aft Bending Mode using openfast, and I found that if I turn off the pitch direction degrees of freedom during the calculation the result looks like this.
If I turn on the pitch degrees of freedom the result is this, which is closer to the value defined by the task,
Here is the information from my elastdyn:
False YawDOF - Yaw DOF (flag)
False PtfmSgDOF - Platform horizontal surge translation DOF (flag)
False PtfmSwDOF - Platform horizontal sway translation DOF (flag)
90 BlPitch(1) - Blade 1 initial pitch (degrees)
90 BlPitch(2) - Blade 2 initial pitch (degrees)
90 BlPitch(3) - Blade 3 initial pitch (degrees) [unused for 2 blades]
0 RotSpeed - Initial or fixed rotor speed (rpm)
5 TTDspFA - Initial fore-aft tower-top displacement (meters)
Which approach should I take and how should I correct it if both are incorrect?
