Hello everyone,
I am working now on the 5 MW barge type FOWT (ITI Energy Barge). I was running decay tests in order to verify the natural frequencies presented in section 5.1 in Matha PhD Thesis (“Model Development and Loads Analysis of an Offshore Wind Turbine on a Tension Leg Platform, with a Comparison to Other Floating Turbine Concepts”).
The decay tests were ran using OpenFAST v3.1
In .fst file, i disabled AeroDyn, Inflow, ServoDyn. In Hydrodyn, i set WaveMod = 0 in order to set “still water” condition. In ElastoDyn file, all DoF are enabled except for NacelleYaw and Teeter.
I obtained important discrepancies in surge, sway and tower 1st mode in side-side. In addition for the heave motion, i used to compute the PSD in log scale to see a little peak at the natural frequency 0.136 Hz. In the linear scale, this peak does not appear. I used MATLAB to compute PSD. For the surge, sway and heave, an initial displacement equals 1 m is used and for the roll, pitch and yaw an initial angle of 1 deg is used. Those values are chosen to remain around the static equilibrium position where the nonlinearities of the mooring lines are considered negligible. Also, for the surge, sway and heave, i ran a decay test for 8000 s and 1500 s for the others.
In the following, a picture shows the natural frequencies obtained versus those present in Matha et al., 2009.
Does anyone encounter the same difference or at least tell me where i did the mistake.
Also, i wanna make sure that 3P (self excitation) excites for example the tower in fore-aft only ? or also in side-side ?
Thank you for your help.
Riad
