Error in running TurbSim
Dear Mohd,
My answer is “yes” to both of your questions. The user-specified options in TurbSim make it completely tailorable to your own mean profile, turbulence spectra, etc.
Hello Dr. Jonkman,
I am trying to generate formatted full-field files (.u, .v and .w) for TIMESR case. The code is running but the these files are not generating with below error in the command window (Capture.PNG).
Could you please let me know where the problem is as I could not figure out?
The error you are showing indicates a problem in the source code. I would first check if the TurbSim executable from OpenFAST has the same issue (you can download a pre-compiled binary here: github.com/OpenFAST/openfast/issues.
hi
I have tried several times to generate wind data with both turbsim v1.5 and turbsim v2 but I get the following error
my code:
TurbSim Input File. Valid for TurbSim v1.50, 25-Sep-2009
2318573 RandSeed1 - First random seed (-2147483648 to 2147483647)
RANLUX RandSeed2 - Second random seed (-2147483648 to 2147483647) for intrinsic pRNG, or an alternative pRNG: “RanLux” or “RNSNLW”
False WrADFF - Output full-field time-series data in TurbSim/AeroDyn form? (Generates Rootname.bts)
True WrBLFF - Output full-field time-series data in BLADED/AeroDyn form? (Generates RootName.wnd)
True WrACT - Output coherent turbulence time steps in AeroDyn form? (Generates RootName.cts)
15 NumGrid_Z - Vertical grid-point matrix dimension
15 NumGrid_Y - Horizontal grid-point matrix dimension
650 AnalysisTime - Length of analysis time series [seconds] (program will add time if necessary: AnalysisTime = MAX(AnalysisTime, UsableTime+GridWidth/MeanHHWS) )
650 UsableTime - Usable length of output time series [seconds] (program will add GridWidth/MeanHHWS seconds)
15.42 HubHt - Hub height [m] (should be > 0.5GridHeight)
6 GridHeight - Grid height [m]
6 GridWidth - Grid width [m] (should be >= 2
(RotorRadius+ShaftLength))
“IECKAI” TurbModel - Turbulence model (“IECKAI”=Kaimal, “IECVKM”=von Karman, “GP_LLJ”, “NWTCUP”, “SMOOTH”, “WF_UPW”, “WF_07D”, “WF_14D”, or “NONE”)
“2-ED2” IECstandard - Number of IEC 61400-x standard (x=1,2, or 3 with optional 61400-1 edition number (i.e. “1-Ed2”) )
“A” IECturbc - IEC turbulence characteristic (“A”, “B”, “C” or the turbulence intensity in percent) (“KHTEST” option with NWTCUP model, not used for other models)
default ETMc - IEC Extreme Turbulence Model “c” parameter [m/s]
“PL” WindProfileType - Wind profile type (“JET”,“LOG”=logarithmic,“PL”=power law,“IEC”=PL on rotor disk,LOG elsewhere, or “default”)
15.42 RefHt - Height of the reference wind speed [m]
7.8 URef - Mean (total) wind speed at the reference height [m/s] (or “default” for JET wind profile)
default PC_UW - Hub mean u’w’ Reynolds stress (or “default”)
default PC_UV - Hub mean u’v’ Reynolds stress (or “default”)
default PC_VW - Hub mean v’w’ Reynolds stress (or “default”)
default IncDec1 - u-component coherence parameters (e.g. “10.0 0.3e-3” in quotes) (or “default”)
default IncDec2 - v-component coherence parameters (e.g. “10.0 0.3e-3” in quotes) (or “default”)
default IncDec3 - w-component coherence parameters (e.g. “10.0 0.3e-3” in quotes) (or “default”)
default CohExp - Coherence exponent (or “default”)
“M:\coh_events\eventdata” CTEventPath - Name of the path where event data files are located
“Random” CTEventFile - Type of event files (“LES”, “DNS”, or “RANDOM”)
1.0 DistScl - Disturbance scale (ratio of wave height to rotor disk). (Ignored when Randomize = true.)
0.5 CTLy - Fractional location of tower centerline from right (looking downwind) to left side of the dataset. (Ignored when Randomize = true.)
0.5 CTLz - Fractional location of hub height from the bottom of the dataset. (Ignored when Randomize = true.)
30.0 CTStartTime - Minimum start time for coherent structures in RootName.cts [seconds]
NOTE: Do not add or remove any lines in this file!
Dear @Ali.Rouhbakhsh,
Your input file is formatted for TurbSim v1.5, but you are running TurbSim v2.0. You must upgrade your input file for compatibility, including adding the following lines:
Line 4, Echo
Line 32, UserFile
Line 38, ProfileFile
Lines 53-57 for a blank line, header, and inputs SCMod1, SCMod2, and SCMod3
See the TurbSim v2.0 documentation and sample models for more information: TurbSim | Wind Research | NREL.
I did what you said, but I think the problem is that I set the IECstandard parameter “2-ed2” in the software input, which causes an error, but when I set this parameter to something else like “1-ed3”, the software runs correctly
my code for turbsim v1.5:
TurbSim Input File. Valid for TurbSim v1.50, 25-Sep-2009; for Certification Test #1 (Kaimal Spectrum, formatted FF files).
123456 RandSeed1 - First random seed (-2147483648 to 2147483647)
789012 RandSeed2 - Second random seed (-2147483648 to 2147483647) for intrinsic pRNG, or an alternative pRNG: “RanLux” or “RNSNLW”
False WrBHHTP - Output hub-height turbulence parameters in GenPro-binary form? (Generates RootName.bin)
True WrFMTFF - Output full-field time-series data in formatted (readable) form? (Generates RootName.u, RootName.v, RootName.w)
650.0 AnalysisTime - Length of analysis time series [seconds] (program will add time if necessary: AnalysisTime = MAX(AnalysisTime, UsableTime+GridWidth/MeanHHWS) )
650.0 UsableTime - Usable length of output time series [seconds] (program will add GridWidth/MeanHHWS seconds)
“2-ed2” IECstandard - Number of IEC 61400-x standard (x=1,2, or 3 with optional 61400-1 edition number (i.e. “1-Ed2”) )
“A” IECturbc - IEC turbulence characteristic (“A”, “B”, “C” or the turbulence intensity in percent) (“KHTEST” option with NWTCUP, not used for other models)
NTM IEC_WindType - IEC turbulence type (“NTM”=normal, “xETM”=extreme turbulence, “xEWM1”=extreme 1-year wind, “xEWM50”=extreme 50-year wind, where x=wind turbine class 1, 2, or 3)
default ETMc - IEC ETM “c” parameter [m/s] (or “default”)
“PL” WindProfileType - Wind profile type (“JET”=Low-level jet,“LOG”=Logarithmic,“PL”=Power law, or “default”)
default PLExp - Power law exponent (or “default”)
default PC_UW - Mean hub u’w’ Reynolds stress (or “default” or “none”)
default PC_UV - Mean hub u’v’ Reynolds stress (or “default” or “none”)
default PC_VW - Mean hub v’w’ Reynolds stress (or “default” or “none”)
“.\EventData” CTEventPath - Name of the path where event data files are located
random CTEventFile - Type of event files (“random”, “les” or “dns”)
true Randomize - Randomize disturbance scale and location? (true/false)
1.0 DistScl - Disturbance scale (ratio of dataset height to rotor disk).
Untitled
my code for turbsim v2:
---------TurbSim v2.00.* Input File------------------------
650 UsableTime - Usable length of output time series [seconds] (program will add GridWidth/MeanHHWS seconds unless UsableTime is “ALL”)
“IECKAI” TurbModel - Turbulence model (“IECKAI”,“IECVKM”,“GP_LLJ”,“NWTCUP”,“SMOOTH”,“WF_UPW”,“WF_07D”,“WF_14D”,“TIDAL”,“API”,“USRINP”,“TIMESR”, or “NONE”)
“unused” UserFile - Name of the file that contains inputs for user-defined spectra or time series inputs (used only for “USRINP” and “TIMESR” models)
“default” ETMc - IEC Extreme Turbulence Model “c” parameter [m/s]
“PL” WindProfileType - Velocity profile type (“LOG”;“PL”=power law;“JET”;“H2L”=Log law for TIDAL model;“API”;“USR”;“TS”;“IEC”=PL on rotor disk, LOG elsewhere; or “default”)
“unused” ProfileFile - Name of the file that contains input profiles for WindProfileType=“USR” and/or TurbModel=“USRVKM” [-]
15.42 RefHt - Height of the reference velocity (URef) [m]
7.8 URef - Mean (total) velocity at the reference height [m/s] (or “default” for JET velocity profile) [must be 1-hr mean for API model; otherwise is the mean over AnalysisTime seconds]
“default” ZJetMax - Jet height [m] (used only for JET velocity profile, valid 70-490 m)
“default” PLExp - Power law exponent [-] (or “default”)
“default” Z0 - Surface roughness length [m] (or “default”)
“default” Latitude - Site latitude [degrees] (or “default”)
0.05 RICH_NO - Gradient Richardson number [-]
“default” UStar - Friction or shear velocity [m/s] (or “default”)
“default” ZI - Mixing layer depth [m] (or “default”)
“default” PC_UW - Hub mean u’w’ Reynolds stress [m^2/s^2] (or “default” or “none”)
“default” PC_UV - Hub mean u’v’ Reynolds stress [m^2/s^2] (or “default” or “none”)
“default” PC_VW - Hub mean v’w’ Reynolds stress [m^2/s^2] (or “default” or “none”)
“default” SCMod1 - u-component coherence model (“GENERAL”,“IEC”,“API”,“NONE”, or “default”)
“default” SCMod2 - v-component coherence model (“GENERAL”,“IEC”,“NONE”, or “default”)
“default” SCMod3 - w-component coherence model (“GENERAL”,“IEC”,“NONE”, or “default”)
“default” InCDec1 - u-component coherence parameters for general or IEC models [-, m^-1] (e.g. “10.0 0.3e-3” in quotes) (or “default”)
“default” InCDec2 - v-component coherence parameters for general or IEC models [-, m^-1] (e.g. “10.0 0.3e-3” in quotes) (or “default”)
“default” InCDec3 - w-component coherence parameters for general or IEC models [-, m^-1] (e.g. “10.0 0.3e-3” in quotes) (or “default”)
“default” CohExp - Coherence exponent for general model [-] (or “default”)
“random” CTEventFile - Type of event files (“LES”, “DNS”, or “RANDOM”)
1 DistScl - Disturbance scale [-] (ratio of event dataset height to rotor disk). (Ignored when Randomize = true.)
0.5 CTLy - Fractional location of tower centerline from right [-] (looking downwind) to left side of the dataset. (Ignored when Randomize = true.)
0.5 CTLz - Fractional location of hub height from the bottom of the dataset. [-] (Ignored when Randomize = true.)
30 CTStartTime - Minimum start time for coherent structures in RootName.cts [seconds]
! NOTE: Do not add or remove any lines in this file!
So what do you think I should do to solve this problem?
If you want to use IEC 61400-2 default scaling, enter 2 for the IECStandard input. The optional edition number for that parameter is only for the -1 standard. 2-Ed2 is not a valid entry.
Dear Sir,
I downloaded TurbSim_v2.00.07a-bjj.exe this file from https://www.nrel.gov/wind/nwtc/turbsim.html. For running this file I need TurbSim.inp file. From where I download this file?
There are sample input files in the self-extracting archive that you’ve already downloaded (double-click that TurbSim_v2.00.07a-bjj.exe file, and it will extract the files, including the TurbSim executable, documentation, and sample input files).
Thanks for your reply. Finally I know to run (syntax in cmd) TurbSim file using TurbSim.inp file.
How I run AeroDyn file after downloading r-test-main file? Which file is necessary to run this? What is the syntax in cmd?
Thankyou
Dear @Aman.Ali,
I’ve answered the similar question you posted in the separate forum topic regarding how to run TurbSim and AeroDyn (How to run TurbSim and AeroDyn?).
After compiling the standalone AeroDyn driver, the input file you need to specify when executing the simulation is the AeroDyn driver input file, as documented here: 4.2.1.5. AeroDyn Driver — OpenFAST v3.3.0 documentation.
