SumPrint error with OpenFAST 3.0
Hi I have a Aerodyn file that gives a “SumPrint” error.
I tried with ECHO - TRUE and the .ech stops at
Tower Influence and Aerodynamics
That part of Aerodyn.dat file is:
======  Rotor Properties  ===========================================================================
TRUE                             UseBlCm - Include aerodynamic pitching moment in calculations? (flag)
"Blade.dat"                  ADBlFile(1) - Name of file containing distributed aerodynamic properties for Blade #1 (file path)
"Blade.dat"                  ADBlFile(2) - Name of file containing distributed aerodynamic properties for Blade #2 (file path)
"Blade.dat"                  ADBlFile(3) - Name of file containing distributed aerodynamic properties for Blade #3 [unused if NumBl < 3] (file path)
======  Tower Influence and Aerodynamics ============================================================= [used only when TwrPotent/=0, TwrShadow=True, or TwrAero=True]
                  11           NumTwrNds  - Number of tower nodes used in the analysis[used only when TwrInflnc/=0, or TwrAero=True] (-)
             TwrElev             TwrDiam               TwrCd               TwrTI
                 (m)                 (m)                 (-)                 (-)
       1.0000000E+01       6.5000000E+00       1.0000000E+00       1.0000000E-01
       1.7760000E+01       6.2400000E+00       1.0000000E+00       1.0000000E-01
       2.5520000E+01       5.9700000E+00       1.0000000E+00       1.0000000E-01
       3.3280000E+01       5.7100000E+00       1.0000000E+00       1.0000000E-01
       4.1040000E+01       5.4500000E+00       1.0000000E+00       1.0000000E-01
       4.8800000E+01       5.1800000E+00       1.0000000E+00       1.0000000E-01
       5.6560000E+01       4.9200000E+00       1.0000000E+00       1.0000000E-01
       6.4320000E+01       4.6600000E+00       1.0000000E+00       1.0000000E-01
       7.2080000E+01       4.4000000E+00       1.0000000E+00       1.0000000E-01
       7.9840000E+01       4.1300000E+00       1.0000000E+00       1.0000000E-01
       8.7600000E+01       3.8700000E+00       1.0000000E+00       1.0000000E-01
======  Outputs  ====================================================================================
FALSE                           SumPrint - Generate a summary file listing input options and interpolated properties to "<rootname>.AD.sum"? (flag)
                   8             NBlOuts - Number of blade node outputs [0 - 9] (-)
1, 2, 3, 4, 5, 6, 7, 8             BlOutNd - Blade nodes whose values will be output (-)
                   9             NTwOuts - Number of tower node outputs [0 - 9] (-)
3, 4, 5, 6, 7, 8, 9, 10, 11             TwOutNd - Tower nodes whose values will be output (-)
It’s running with V2.6.
Can you please point out the error in this w.r.t V3.0
Dear @Ashok.Jammi,
I’m not aware of changes made to the AeroDyn input file between v2.6 and v3.0 of OpenFAST, but can you share your complete AeroDyn input file and Echo file?
Hi @Jason.Jonkman ,
AeroDyn file:
------- AERODYN v15.02.* INPUT FILE -----------------------------------------------------------------
OC4 3.1 Modified (control system test)
======  General Options  ============================================================================
TRUE                               Echo - Echo input to "<rootname>.AD.ech"? (flag)
"DEFAULT"                         DTAero - Time interval for aerodynamic calculations {or "default"} (s)
                   1             WakeMod - Type of wake/induction model (switch)
                   2           AFAeroMod - Type of blade aerofoil aerodynamics model (switch)
                   1           TwrPotent - Type tower influence on wind based on potential flow around the tower (switch)
                   0           TwrShadow - Calculate tower influence on wind based on downstream tower shadow? (switch)
TRUE                             TwrAero - Calculate tower aerodynamic loads? (flag)
FALSE                         FrozenWake - Assume frozen wake during linearization? (flag)
FALSE                         CavitCheck - Perform cavitation check? (flag)
FALSE                             CompAA - Flag to compute AeroAcoustics calculation (flag)
"UNUSED"                    AA_InputFile - AeroAcoustics input file (file path)
======  Environmental Conditions  ===================================================================
               1.225             AirDens - Air density (kg/m^3)
           1.464E-05             KinVisc - Kinematic air viscosity (m^2/s)
                 335            SpdSound - Speed of sound (m/s)
              103500                Patm - Atmospheric pressure (Pa)
                1700                Pvap - Vapour pressure of fluid (Pa)
                 0.5          FluidDepth - Water depth above mid-hub height (m)
======  Blade-Element/Momentum Theory Options  ====================================================== [used only when WakeMod=1]
                   2             SkewMod - Type of skewed-wake correction model (switch)
"DEFAULT"                  SkewModFactor - Constant used in Pitt/Peters skewed wake model {or "default" is 15/32*pi} (-)
TRUE                             TipLoss - Use the Prandtl tip-loss model? (flag)
TRUE                             HubLoss - Use the Prandtl hub-loss model? (flag)
TRUE                              TanInd - Include tangential induction in BEMT calculations? (flag)
FALSE                             AIDrag - Include the drag term in the axial-induction calculation? (flag)
FALSE                             TIDrag - Include the drag term in the tangential-induction calculation? (flag)
"DEFAULT"                       IndToler - Convergence tolerance for BEM induction factors (radians)
                 100             MaxIter - Maximum number of iteration steps (-)
======  Dynamic Blade-Element/Momentum Theory Options  ====================================================== [used only when WakeMod=2]
                   2           DBEMT_Mod - Type of dynamic BEMT (DBEMT) model (switch)
                   4          tau1_const - Time constant for DBEMT (s)
======  OLAF -- cOnvecting LAgrangian Filaments (Free Vortex Wake) Theory Options  ====================================================== [used only when WakeMod=3]
"UNUSED"               OLAFInputFileName - Input file for OLAF (file path)
======  Beddoes-Leishman Unsteady Aerofoil Aerodynamics Options  ===================================== [used only when AFAeroMod=2]
                   3               UAMod - Unsteady Aero Model Switch (switch)
TRUE                             FLookup - Flag to indicate whether a lookup for f' will be calculated (TRUE) or whether best-fit exponential equations will be used (FALSE); if FALSE S1-S4 must be provided in aerofoil input files (flag) [used only when AFAeroMod=2] (flag)
======  Aerofoil Information =========================================================================
                   1            AFTabMod - Interpolation method for multiple airfoil tables (switch)
                   1          InCol_Alfa - The column in the aerofoil tables that contains the angle of attack (-)
                   2            InCol_Cl - The column in the aerofoil tables that contains the lift coefficient (-)
                   3            InCol_Cd - The column in the aerofoil tables that contains the drag coefficient (-)
                   4            InCol_Cm - The column in the aerofoil tables that contains the pitching-moment coefficient; use zero if there is no Cm column (-)
                   0         InCol_Cpmin - The column in the aerofoil tables that contains the drag coefficient; use zero if there is no Cpmin column (-)
                   8          NumAFfiles - Number of aerofoil files used (-)
"..\Aerofoils\Cylinder1_1000Hz.dat"             AfNames - Aerofoil file names (NumAFfiles lines) (file path)
"..\Aerofoils\Cylinder2_1000Hz.dat"
"..\Aerofoils\DU40_A17_1000Hz.dat"
"..\Aerofoils\DU35_A17_1000Hz.dat"
"..\Aerofoils\DU30_A17_1000Hz.dat"
"..\Aerofoils\DU25_A17_1000Hz.dat"
"..\Aerofoils\DU21_A17_1000Hz.dat"
"..\Aerofoils\NACA64_A17_1000Hz.dat"
                 (m)                 (m)                 (-)                 (-)
"RtAeroPwr"                              ! Rotor aerodynamic power
"RtSpeed"                                ! Rotor speed
"TwN9VUndx"                              ! Undisturbed wind velocity at top of tower
"TwN1VUndx"                              ! Undisturbed wind velocity at base of tower
"RtAeroFxh"                              ! Rotor aerodynamic force Fx (wind direction)
"RtAeroFyh"                              ! Rotor aerodynamic force Fy (lateral direction)
"RtAeroFzh"                              ! Rotor aerodynamic force Fz (vertical direction)
"RtAeroMxh"                              ! Rotor aerodynamic moment Mx (roll direction)
"RtAeroMyh"                              ! Rotor aerodynamic moment My (pitch direction)
"RtAeroMzh"                              ! Rotor aerodynamic moment Mz (yaw direction)
END
ECHO file:
Echo file for AeroDyn 15 primary input file: <FILE PATH>
 TRUE            = Echo
 DEFAULT         = DTAero
 1               = WakeMod
 2               = AFAeroMod
 1               = TwrPotent
 0               = TwrShadow
 TRUE            = TwrAero
 FALSE           = FrozenWake
 FALSE           = CavitCheck
 FALSE           = CompAA
 UNUSED          = AA_InputFile
 1.225           = AirDens
 1.464E-05       = KinVisc
 335             = SpdSound
 103500          = Patm
 1700            = Pvap
 0.5             = FluidDepth
 2               = SkewMod
 DEFAULT         = SkewModFactor
 TRUE            = TipLoss
 TRUE            = HubLoss
 TRUE            = TanInd
 FALSE           = AIDrag
 FALSE           = TIDrag
 DEFAULT         = IndToler
 100             = MaxIter
 2               = DBEMT_Mod
 4               = tau1_const
 UNUSED          = OLAFInputFileName
 3               = UAMod
 TRUE            = FLookup
 1               = AFTabMod
 1               = InCol_Alfa
 2               = InCol_Cl
 3               = InCol_Cd
 4               = InCol_Cm
 0               = InCol_Cpmin
 8               = NumAFfiles
 ..\Aerofoils\Cy = AfNames
 ..\Aerofoils\Cy =
 ..\Aerofoils\DU =
 ..\Aerofoils\DU =
 ..\Aerofoils\DU =
 ..\Aerofoils\DU =
 ..\Aerofoils\DU =
 ..\Aerofoils\NA =
 TRUE            = UseBlCm
 Blade.dat       = ADBlFile(1)
 Blade.dat       = ADBlFile(2)
 Blade.dat       = ADBlFile(3)
Thank you,
Ashok
Thanks, @Ashok.Jammi
Could you also share the full message written to the command prompt when you execute OpenFAST v3.0?
Hi @Jason.Jonkman ,
Error: Init_AeroDyn:AD_Init:ParsePrimaryFileInfo:ParseLoVar:
>> A fatal error occurred when parsing data from <FILE PATH>
>> The variable "SumPrint" was not found on line #62
Thank you,
Ashok
Dear @Ashok.Jammi,
Can you verify the exact version information for OpenFAST (at the very top of the output at the command line)? I am not able to reproduce your error with 3.0.0.
Hi @Andy.Platt ,
yes it’s version 3.0.0.
@Jason.Jonkman ,
I see that from V3.0.0 - AeroDyn accepts multiple rotors. Does that affect input file in anyway ?
Dear @Ashok.Jammi,
Certainly the AeroDyn input file looks different if you are modeling multiple rotors through the standalone AeroDyn driver (as documented here: 4.2.1.6. AeroDyn Driver — OpenFAST v3.5.3 documentation), but the AeroDyn input file should be unchanged if you are only modeling a single rotor.
