Yes I am using the master branch of the MATLAB-Toolbox and yes I had to make few changes to the runCampbell script to make it use the dat files for the 5MW_Land_ModeShapes case as the master branch does not have the template dat files which I already mentioned here in the forum. There are a few other changes like reducing the size of arrays like WindSpeedAry =[3, 4, 5]; %(m/sec). Please see below the runCampbell code for your reference (I am sorry for the spamming this post with the matlab code as I had a problem attaching the txt file). I guess the script that you have on your end may be different from the script on the master branch because if you look at line number 184 in runCampbell script the number of arguments is 5 while the function campbell_diagram_data accepts only 4 arguments. I tried to change this in the script but I get new errors with xlswrite function.
I noticed the code to the function CampbellMatchModeNames used in runCampbell is missing. There are also parts of the code (like the copy command at line 180 and xlswrite, which does not work on Mac OS) that are OS-dependent. I think this script has not been carefully tested before committing to the github repository. Please correct me if I am wrong.
Thank you,
Srinivasa
------runCampbell.m------
% by Bonnie Jonkman
% (c) 2016 National Renewable Energy Laboratory
% (c) 2018 Envision Energy, USA
%% let's get the directory that contains the template files
templateDir = [ '..\..\ConvertFASTversions\TemplateFiles'];
% IfWtemplate = [templateDir filesep 'InflowWind.dat'];
% SrvDtemplate = [templateDir filesep 'ServoDyn.dat'];
% EDtemplate = [templateDir filesep 'ElastoDyn.dat'];
% FASTtemplate = [templateDir filesep 'OpenFAST.dat'];
% VizTemplate = [templateDir filesep 'OpenFAST-Modes.viz'];
% WriteVTKmodes = true;
% WriteFASTfiles = true;
IfWtemplate = ['MYPATH/TemplateFiles/NRELOffshrBsline5MW_InflowWind_Steady13mps.dat'];
SrvDtemplate = ['MYPATH/TemplateFiles/NRELOffshrBsline5MW_Onshore_ServoDyn.dat'];
EDtemplate = ['MYPATH/TemplateFiles/NRELOffshrBsline5MW_Onshore_ElastoDyn.dat'];
FASTtemplate = 'MYPATH/TemplateFiles/OpenFAST.dat';
Viztemplate = 'MYPATH/TemplateFiles/OpenFAST-Modes.viz';
%VizTemplate = [templateDir filesep 'OpenFAST-Modes.viz'];
WriteVTKmodes = false;
%% Executable and base file:
% FASTexe = '..\..\bin\openFAST_Win32.exe';
% FSTName = 'OpenFAST.fst';
% VizFile = 'OpenFAST-Modes.viz';
FASTexe = 'MYPATHTPOF/OpenFAST/OpenFAST-373/build/bin/openfast';
%FSTName = 'OpenFAST.fst';
FSTName = 'MYPATHTOINPUT/OpenFAST/5MW_Land_ModeShapes/5MW_Land_ModeShapes.fst';
%% Read data from original files (for modification):
[oldDir, baseName, ext ] = fileparts(FSTName);
if strcmp(oldDir,filesep)
oldDir = ['.' filesep];
end
XLSname = [baseName '-CampbellData.xlsx']; % name for spreadsheet to write
FP = FAST2Matlab(FSTName,2); %FP are Fast Parameters, specify 2 lines of header (FAST 8)
[IfWP, InflowFile] = GetFASTPar_Subfile(FP, 'InflowFile', oldDir, oldDir);
[SrvP, ServoFile] = GetFASTPar_Subfile(FP, 'ServoFile', oldDir, oldDir);
[EP, EDFile] = GetFASTPar_Subfile(FP, 'EDFile', oldDir, oldDir);
CompElast = GetFASTPar(FP, 'CompElast');
CompInflow = GetFASTPar(FP, 'CompInflow');
CompServo = GetFASTPar(FP, 'CompServo');
CompAero = GetFASTPar(FP, 'CompAero');
TipRad = GetFASTPar(EP, 'TipRad');
HubRad = GetFASTPar(EP, 'HubRad');
BladeLen = TipRad - HubRad;
TowerLen = GetFASTPar(EP, 'TowerHt');
if WriteVTKmodes
VizP = FAST2Matlab(VizFile,2);
WrVTK = 3;
else
WrVTK = 0;
end
%% modify data, write new files (if necessary), and run
% RotSpeedAry = 0:2:14; %10; %0:2:14; %rpm
% WindSpeedAry = [];
% CompInflow = 0;
% CompAero = 0;
%% ED 5MW values:
%WindSpeedAry =[3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25]; %(m/sec)
%RotSpeedAry = [6.972, 7.183, 7.506, 7.942, 8.469, 9.156, 10.296, 11.431, 11.89, 12.1, 12.1, 12.1, 12.1, 12.1, 12.1, 12.1, 12.1, 12.1, 12.1, 12.1, 12.1, 12.1, 12.1]; %(rpm)
%BldPitch1 = [0, 0, 0, 0, 0, 0, 0, 0, 0, 3.823, 6.602, 8.668, 10.45, 12.055, 13.536, 14.92, 16.226, 17.473, 18.699, 19.941, 21.177, 22.347, 23.469]; % (deg)
%GenTqAry = [0.606, 2.58, 5.611, 9.686, 14.62, 20.174, 25.51, 31.455, 40.014, 43.094, 43.094, 43.094, 43.094, 43.094, 43.094, 43.094, 43.094, 43.094, 43.094, 43.094, 43.094, 43.094, 43.094]*1000; %(N-m)
RotSpeedAry = [6.972, 7.183, 7.506]; %(rpm)
BldPitch1 = [0, 0, 0]; % (deg)
GenTqAry = [0.606, 2.58, 5.611]*1000; %(N-m)
SimTime = 5600; % time in seconds that the first linearization output will happen (maximum time to converge to steady-state solution)
RatedWindSpeed = 11.4;
nPoints = max( length(RotSpeedAry), length(WindSpeedAry) );
FAST_linData = cell(nPoints,1); % raw data read from FAST's .lin files
getMatData = cell(nPoints,1); % FAST .lin data converted to format that MBC can process
MBC_data = cell(nPoints,1); % processed MBC3 data
CampbellData = cell(nPoints,1);
for i_case = nPoints:-1:1
if (CompAero > 0)
wkSheetName = [ num2str(WindSpeedAry(i_case)), ' mps' ];
else
wkSheetName = [ num2str(RotSpeedAry(i_case)), ' RPM' ];
end
if ( RotSpeedAry(i_case) == 0 )
NLinTimes = 1;
else
NLinTimes = 36;
end
%newFASTbase = [ baseName, '-', strrep(wkSheetName,' ','') ];
newFASTbase = [ oldDir, '/', baseName, '-', strrep(wkSheetName,' ','') ];
newFSTName = [ newFASTbase ext ];
FileNames = strcat( strrep(newFSTName, '.fst','.'), strrep( cellstr(num2str( (1:NLinTimes)' )), ' ', ''), '.lin' );
if WriteFASTfiles
if (WindSpeedAry(i_case) > RatedWindSpeed && CompAero > 0)
GenTq = 43094;
TrimCase = 3;
% TrimGain = .1 / (RotSpeedAry(i_case) * pi/30); %-> convert RotSpeed to rad/s
% TrimGain = TrimGain*0.1
TrimGain = 0.001;
else
GenTq = GenTqAry(i_case);
TrimCase = 2;
% TrimGain = 3340 / (RotSpeedAry(i_case) * pi/30); %-> convert RotSpeed to rad/s
TrimGain = 300;
end
% InflowWind
if CompInflow > 0
IfWP_mod = SetFASTPar(IfWP,'HWindSpeed',WindSpeedAry(i_case));
Matlab2FAST(IfWP_mod,IfWtemplate, InflowFile, 2); %contains 2 header lines
end
% ServoDyn
if CompServo > 0
SrvP_mod = SetFASTPar(SrvP,'VS_RtTq',GenTq);
Matlab2FAST(SrvP_mod,SrvDtemplate, ServoFile, 2); %contains 2 header lines
end
% ElastoDyn
EP_mod = SetFASTPar(EP, 'RotSpeed',RotSpeedAry(i_case));
if CompInflow > 0
EP_mod = SetFASTPar(EP_mod,'BlPitch(1)',BldPitch1(i_case));
EP_mod = SetFASTPar(EP_mod,'BlPitch(2)',BldPitch1(i_case));
EP_mod = SetFASTPar(EP_mod,'BlPitch(3)',BldPitch1(i_case));
end
Matlab2FAST(EP_mod, EDtemplate, EDFile, 2); %contains 2 header lines
FP_mod = SetFASTPar(FP,'TMax',SimTime);
FP_mod = SetFASTPar(FP_mod,'Linearize','true');
FP_mod = SetFASTPar(FP_mod,'CalcSteady','true');
FP_mod = SetFASTPar(FP_mod,'NLinTimes',NLinTimes);
FP_mod = SetFASTPar(FP_mod,'TrimCase', TrimCase);
FP_mod = SetFASTPar(FP_mod,'TrimGain', TrimGain);
FP_mod = SetFASTPar(FP_mod,'TrimTol', 1e-3);
FP_mod = SetFASTPar(FP_mod,'Twr_Kdmp', 0);
FP_mod = SetFASTPar(FP_mod,'Bld_Kdmp', 0);
FP_mod = SetFASTPar(FP_mod,'OutFmt','"ES20.12E3"'); % make sure we get enough digits of precision
FP_mod = SetFASTPar(FP_mod,'WrVTK',WrVTK);
Matlab2FAST(FP_mod,FASTtemplate, newFSTName, 2); %contains 2 header lines
%% Run FAST with new input files
status = system([FASTexe ' ' newFSTName]);
if status ~= 0 % check that we have some output here
break
end
end
%% Analyze results from .lin files (azimuth average)
if WriteVTKmodes
ModesVizName = [newFASTbase '.ModeShapeVTK' ];
[MBC_data{i_case}, getMatData{i_case}, FAST_linData{i_case}] = fx_mbc3( FileNames, ModesVizName );
VizP = SetFASTPar(VizP,'CheckpointRoot',strrep(newFSTName,'.fst', '.ModeShapeVTK'));
VizP = SetFASTPar(VizP,'MatlabFileName',ModesVizName);
Matlab2FAST(VizP,VizTemplate, VizFile, 2); %contains 2 header lines
system( [FASTexe ' -VTKLin ' VizFile]);
system(['copy fort.51 ' strrep( newFSTName, '.fst','.viz.51' )]);
else
[MBC_data{i_case}, getMatData{i_case}, FAST_linData{i_case}] = fx_mbc3( FileNames );
end
[CampbellData{i_case}] = campbell_diagram_data(MBC_data{i_case}, BladeLen, TowerLen, [], strrep(newFSTName,'.fst','.MBD.sum'));
% write results at this RPM/WindSpeed to Excel worksheet
try
xlswrite(XLSname, CampbellData{i_case}.ModesTable, wkSheetName); % create a worksheet with these modes
catch
disp(['warning::could not write Campbell data in Excel worksheet for ' wkSheetName]);
end
end
% [modeID_table, modesDesc] = IdentifyModes(CampbellData);
[modeID_table, modesDesc] = CampbellMatchModeNames(CampbellData);
opTable = cell(3,nPoints+1);
opTable{1,1} = 'Operating Points';
opTable{2,1} = 'Wind Speed (mps)';
opTable{3,1} = 'Rotor Speed (rpm)';
for i=1:nPoints
opTable{2,i+1} = CampbellData{i}.WindSpeed;
opTable{3,i+1} = CampbellData{i}.RotSpeed_rpm;
end
thisTable = cell(length(modesDesc)+2,nPoints+1);
thisTable{1,1} = 'Mode Number Table';
if (CompAero > 0)
thisTable{2,1} = 'Wind Speed (mps)';
thisTable(2,2:end) = num2cell(WindSpeedAry);
wkSheetName = 'WS_ModesID';
else
thisTable{2,1} = 'Rotor Speed (rpm)';
thisTable(2,2:end) = num2cell(RotSpeedAry);
wkSheetName = 'ModesID';
end
for i = 1:length(modesDesc)
thisTable(i+2,1) = modesDesc(i);
end
thisTable(3:end,2:end) = num2cell(modeID_table);
try
xlswrite(XLSname, thisTable, wkSheetName); % create a worksheet with these modes
xlswrite(XLSname, opTable, 'OP'); % create a worksheet with these operating points
catch
disp(['warning::could not write modes identification data in Excel worksheet for ' wkSheetName]);
end
[num,txt,CampbellPlotData] = Plot_CampbellData(XLSname,wkSheetName);
