Problems when using TLCD in NREL5MW_OC4
Version 4.0.2
I try to use TLCD in NREL_5MW+OC4 float wind turbine, but i face several problems
The outside condition is free damper: [8deg PtfmPitch]
  1. i try to install a X_TLCD to the NumNStC, and this is what i write in the TLCD.dat
---------------------- StC LOCATION ------------------------------------------- [relative to the reference origin of component attached to]
0 StC_P_X - At rest X position of StC (m)
0 StC_P_Y - At rest Y position of StC (m)
0 StC_P_Z - At rest Z position of StC (m)
---------------------- TLCD --------------------------------------------------- [used only when StC_DOF_MODE=3]
18.8200 L_X - X TLCD total length (m)
16.0000 B_X - X TLCD horizontal length (m)
3.6600 area_X - X TLCD cross-sectional area of vertical column (m^2)
4.4103 area_ratio_X - X TLCD cross-sectional area ratio (vertical column area divided by horizontal column area) (-)
17.0000 headLossCoeff_X - X TLCD head loss coeff (-)
1025 rho_X - X TLCD liquid density (kg/m^3)
0.0000 L_Y - Y TLCD total length (m)
0.0000 B_Y - Y TLCD horizontal length (m)
0.0000 area_Y - Y TLCD cross-sectional area of vertical column (m^2)
0.0000 area_ratio_Y - Y TLCD cross-sectional area ratio (vertical column area divided by horizontal column area) (-)
0.0000 headLossCoeff_Y - Y TLCD head loss coeff (-)
1025 rho_Y - Y TLCD liquid density (kg/m^3)
But this give me an error like this:
The BEM solution is being turned off due to low TSR. (TSR = 0). This warning will not be
repeated though the condition may persist. (See GeomPhi output channel.)
NaN detected at time 1.00000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.00000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.00000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.05000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.05000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.05000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.10000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.10000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.10000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.15000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.15000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.15000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.20000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.20000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.20000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.25000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.25000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.25000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.30000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.30000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.30000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.35000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.35000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.35000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.40000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.40000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.40000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.45000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.45000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.45000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.50000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.50000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.50000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.55000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.55000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.55000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.60000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.60000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.60000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.65000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.65000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.65000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.70000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.70000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.70000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.75000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.75000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.75000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.80000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.80000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.80000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.85000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.85000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.85000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.90000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.90000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.90000E-02 in Line 3 in MoorDyn.
NaN detected at time 1.95000E-02 in Line 1 in MoorDyn.
NaN detected at time 1.95000E-02 in Line 2 in MoorDyn.
NaN detected at time 1.95000E-02 in Line 3 in MoorDyn.
FAST_Solution:FAST_UpdateStates:FAST_AdvanceStates: NaN state detected.
MD_UpdateStates: NaN state detected.
OpenFAST encountered an error at simulation time 2.00000E-02 of 1200 seconds.
Aborting OpenFAST.
2. How to balance the add-mass by reduce the water?
I try to keep the average of PtfmHeave alomst the same to the origin data, so i try to calculate the mass of the TLCD by the following function:
the origin water level: -6.17m
the water filled = -6.17 - [L-B+(B/area_ratio)](area_X)/(3PI*(6-0.06)^2)
And if the TLCD is the same in X and Y direction then i think that the water filled is
-6.17 - 2*[L-B+(B/area_ratio)](area_X)/(3PI*(6-0.06)^2)
In another example of A TLCD installed to NumSStC
-19 StC_P_Z - At rest Z position of StC (m)
14.5000 L_X - X TLCD total length (m)
5.5000 B_X - X TLCD horizontal length (m)
0.7854 area_X - X TLCD cross-sectional area of vertical column (m^2)
8.7971 area_ratio_X - X TLCD cross-sectional area ratio (vertical column area divided by horizontal column area) (-)
2.0000 headLossCoeff_X - X TLCD head loss coeff (-)
14.5000 L_Y - Y TLCD total length (m)
5.5000 B_Y - Y TLCD horizontal length (m)
0.7854 area_Y - Y TLCD cross-sectional area of vertical column (m^2)
8.7971 area_ratio_Y - Y TLCD cross-sectional area ratio (vertical column area divided by horizontal column area) (-)
2.0000 headLossCoeff_Y - Y TLCD head loss coeff (-)
By the function, i get the water filled= -6.215465908
But The .outb result of PtfmHeave was different from what I had expected.
This is the two main problems i reached in the test, beside this, Are there any suggestion or good TLCD configuration parameters that can be used to suppress PtfmPitch? The effects of the several TLCDs I tested were not satisfactory.
Dear @Wenbo.Zhong,
If I understand correctly, you are adding a TLCD to the nacelle by setting NumNStC = 1 in ServoDyn and using StC_DOF_MODE = 3 in the Structural Control (StC) submodel; is that correct?
Can you clarify the equation you are using to keep the PtfmHeave unchanged; I’m not following your math. What is the TLDC mass you are adding to the nacelle in both cases?
Dear @Jason.Jonkman
In the first quesiton, yes, i add a X direction TLCD to nacelle by setting
NumNStC = 1
StC_DOF_MODE = 3
And, the TLCD mass as i thought is calculated by
m_TLCD_x = rho_x * area_X * [ L_X - B_X + B_X / area_ratio_X ]
Then I hope to keep PtfmHeave average unchanged by reducing the water volume in the upper pressure water tanks within the three side columns.
A_upper_water_tank = PI * r^2 = PI * (6-0.06)^2
delta_h = ( m_TLCD_x / rho_x ) / ( 3 * A_upper_water_tank )
As the origin water filled in the upper water tanks is at -6.17m
After i added the TLCD, i think that i should change it to:
-6.17m - delta_h
In the second question, i added a TLCD which have the same parameter in X and Y direction to the platform by
NumSStC = 1
And the mass of TLCD is calculated by
m_TLCD = m_TLCD_x + m_TLCD_y
And the water filled level is
delta_h = ( m_TLCD / rho_x ) / ( 3 * A_upper_water_tank )
-6.17m - delta_h
Dear @Wenbo.Zhong,
Thanks for clarifying. I believe I now understand your approach.
In the first case, you’ve moved a lot of water ballast from deep within the floater to the nacelle. I suspect this is making your model physically and/or numerically unstable.
In the second case, you’ve moved the fixed water ballast to movable water ballast within the TLCD. As such, I suspect that as the floater pitches (due to the overhanging weight of the rotor-nacelle assembly), the TLCD ballast is also shifting, which causes more pitching, and some coupling to heave.
Dear @Jason.Jonkman,
Regarding the second question, I think what you said makes sense. And I adjusted the results based on -6.17m - delta_h to keep the average value of PtfmHeave almost unchanged.
But for the first question, i think there maybe some bugs.
if i use the following parameters:
     2.6600   area_X          - X TLCD cross-sectional area of vertical column (m^2)
     3.4103   area_ratio_X    - X TLCD cross-sectional area ratio (vertical column area divided by horizontal column area) (-)
it will return error like this:
 Running HydroDyn.
 Reading in WAMIT output with root name "D:\MYwork\OpenFAST\5MW_Baseline\HydroData\marin_semi".
 Calculating second order difference-frequency force using the full quadratic transfer function.
 Calculating second order sum-frequency force using the full quadratic transfer function.
 Running MoorDyn (v2.2.2, 2024-01-16).
   This is MoorDyn v2, with significant input file changes from v1.
MoorDyn
Copyright (C) 2025 National Renewable Energy Laboratory
Copyright (C) 2025 Envision Energy USA LTD
   Parsing MoorDyn input file: D:\MYwork\OpenFAST\5.1FD\Baseline\MoorDyn.dat
   Created mooring system:  3 lines, 6 points, 0 rods, 0 bodies.
   Catenary solve of Line 1 unsuccessful. Initializing as linear.
   Catenary solve of Line 2 unsuccessful. Initializing as linear.
   Catenary solve of Line 3 unsuccessful. Initializing as linear.
   Finalizing initial conditions using dynamic relaxation.
   t=46.4  FairTen 1: 1.11571E+06, 1.11715E+06, 1.11826E+06
   Fairlead tensions converged to 1% after 46.4 seconds.
   Fairlead tension: 1.11571E+06
   Fairlead forces: 4.64209E+05, 7.95401E+05, -6.29806E+05
   Fairlead tension: 1.12108E+06
   Fairlead forces: -9.18577E+05, 0, -6.42687E+05
   Fairlead forces: 4.64209E+05, -7.95401E+05, -6.29806E+05
   MoorDyn initialization completed.
 Running ServoDyn.
 Running StrucCtrl.
 Running ServoDyn Interface for Bladed Controllers (using Intel Visual Fortran for Windows).
Using legacy Bladed DLL interface.
FAST_InitializeAll:ED_Init:ED_ReadInput:ReadBladeInputs:ReadBladeFile:The ElastoDyn Blade file,
D:\MYwork\OpenFAST\5MW_Baseline\NRELOffshrBsline5MW_Blade.dat, DISTRIBUTED BLADE PROPERTIES table
contains the PitchAxis column.  This column is unused and will be removed in future releases
FAST_InitializeAll:SeaSt_Init:SeaStateInput_ProcessInitData:WvHiCOff adjusted to 2.61799E-03
rad/s, based on WaveDT.
 Time: 0 of 1200 seconds.
 Aborting OpenFAST.
But If i use the following parameters:
    18.8200   L_Y             - Y TLCD total length (m)
    16.0000   B_Y             - Y TLCD horizontal length (m)
     0.0001   area_Y          - Y TLCD cross-sectional area of vertical column (m^2)
     1.0000   area_ratio_Y    - Y TLCD cross-sectional area ratio (vertical column area divided by horizontal column area) (-)
    17.0000   headLossCoeff_Y - Y TLCD head loss coeff (-)
You can see that area_Y = 0.0001 which add a very little mass to Y_TLCD,
then OpenFAST can run smoothly to the end
I don’t fully understand the specific code, but I suspect that there is a lack of a logical judgment here: the logic for enabling the TLCD in the X or Y direction, or in both X and Y directions.
Beside these, in the OutListParameters.xlsx. I don’t find the parameters related to TLCD
In my concern, i think that this two parameters can indicate the operating status of the TLCD
(openfast.readthedocs.io_4.16.3)
Dear @Wenbo.Zhong,
Interesting; I was not previously aware of these issues with StC. I’ve now posted this issue on OpenFAST GitHub: Bug report: Lack of Data Sanity Checks and Write Outputs for TLCDs in Structural Control (StC) · Issue #2896 · OpenFAST/openfast · GitHub.
Best regards.
