If I do the evaluation at the platform level PtfmRDyi I get the following results:
If I do the evaluation at TwHt1RDyt I get the following results:
In both cases they are not right.
By fixing all the DOF’s at the platform I get the following results at TwHt1RDyt, which are in the expected range.
Thank you.
Mário
Dear @Mario.Sobrinho,
Regarding PtfmRDyi, this is the pitch rotation at the transition piece as output by ElastoDyn. From what I can tell, the turbine is simply falling over, suggesting SoilDyn is not providing a reasonable reaction moment with DLL_model = 1. The platform-pitch DOF calculation in ElastoDyn makes use of a moderate angle correction that loses considerable accuracy beyond about 20 degrees. So, I would not expect an accurate result after about 8 s into your simulation.
As commented before, I would run the simulation with the next settings:
- ElastoDyn: PtfmSgDOF = PtfmSwDOF = PtfmHvDOF = PtfmRDOF = PtfmPDOF = PtfmYDOF = True
- SubDyn: JointType = 1 and all DOFs constrained in the reaction joint except the rotation around Y axis. This is: RctTDXss = RctTDYss = RctTDZss = RctRDXss = RctRDZss = 1. RctRDYss = 0.
- OpenFAST input file: NumCrctn = 1 (one correction iteration).
Now, regarding SoilDyn it seems that is quite challenging with REDWIN model 1. So, as a first attempt to understand what is going on, I would propose you to use CalcOption 1 and define a linear stiffness (K55 position in the stiffness matrix). Hopefully, this will work as expected. Fingers crossed…
If you can successfully run with CalcOption 1, then you can switch to CalcOption 3 and try the REDWIN model 1 with a simple force/deflection relationship similar to what you used in CalcOption 1 (K55 stiffness). So we are adding complexity into the model step by step.
Roger
Dear Jason, dear Roger,
Thank you for your replies.
Dear @Roger.Bergua, I ran a simulation considering the 3 points that you mentioned. In SoilDyn I used CalcOption 1 with a linear stiffness value in K55 as you suggested. Unfortunately I got the same results as before, i. e., model stops at the beginning.
I decided to lock all the DOF’s of the platform, except the PtfmPDOF. I did it for the ElastoDyn input file, as well as for the SubDyn input file. With this approach, I was able to run the model without any error message.
When I switch to CalcOption 3, the system fails as before. For this case, I used a linear relation moment/rotation with the same stiffness used in CalcOption 1.
I have one additional question related with the rotation output. By looking at the rotations at the platform (PtfmRDyi) and at the base of the tower (TwHt1RDyt), the numbers are very different, with the rotation at the platform strangely high, as you can see from the plots below. Even if the rotation of the platform was correct, I would expect a higher rotation in the tower due to some deflection and not the opposite. Do you have any idea why is this happening?
Thank you.
Mário
I’m surprised the model is not running with CalcOption = 1 in SoilDyn. Did you set the (5,5) element of the stiffness matrix in SoilDyn appropriately?
I would not recommend disabling all ElastoDyn platform DOFs except PtfmPDOF. This would eliminate all Guyan modes except for the interface pitch mode. Again, you should keep all of the ElastoDyn platform DOFs enabled and only lock the pitch DOF of the SubDyn reaction joint.
ElastoDyn output PtfmRDyi is the rotation of the platform reference point in the inertial (i) coordinate system; this angle could get large if the tower is unconstrained (as shown by your results). ElastoDyn output TwHt1RDyt is the rotation of the tower output node 1 relative to the platform in the tower-base coordinate system; I would expect this angle to remain small because the tower deflections should be small.
Yes, I believe I did it right. Please, see below:
------- SoilDyn v1.0 INPUT FILE ------------------------------------------------------------------------------
Example SoilDyn input file for stiffness matrix in the seabed.
False Echo - Echo input data to <RootName>.ech (flag)
"default" DT - Communication interval (s) (or "default")
1 CalcOption - Calculation option {1: Stiffness / Damping matrices, 2: P-Y curves [unavailable], 3: coupled REDWIN DLL}
================== Parameters for Stiffness / Damping matrices [used only for CalcOption = 1] ================
0 0 -0.2 Location (X,Y,Z) - the location of interface point (only one point allowed)
Stiffness matrix (6x6)
0.0000e+00 0.0000e+00 0.0000e+00 0.0000e+00 0.0000e+00 0.0000e+00
0.0000e+00 0.0000e+00 0.0000e+00 0.0000e+00 0076013808 0.0000e+00
Damping ratio matrix (6x6)
If I understood correctly your answer related to the rotations, the TwHt1RDyt is the rotation relative to the rotated platform? The accumulated rotation at node 1 would be the PtfmRDyi + TwHt1RDyt. Is that correct?
Thank you.
Mário
Does the (5,5) element of the stiffness matrix actually have leading zeros? I’m not sure how this would be interpreted.
I agree with your calculation of the total rotation of ElastoDyn tower output node 1.
How big (or small) is your wind turbine? The bending stiffness that you are defining is 7.6E7 Nm/rad. This value is certainly small. For example, the rated thrust force of the IEA-10.0-198-RWT is close to 1.5E6 N. Assuming a distance between the tower top and the seabed of 100 m, the bending moment at the seabed would be 1.5E8 Nm. This bending moment would make your monopile rotate 1.97 rad…
In the section 3.3.1 of the next technical report (https://www.nrel.gov/docs/fy21osti/79938.pdf), you can see the stiffness matrix used during the OC6 phase II project. The bending stiffness is 8.1E11 Nm/rad. This is 4 orders of magnitude stiffer than the value that you are using.
Finally, it is important to note that if you are using CalcOption 1 in SoilDyn you are just defining a stiffness matrix as the boundary condition for the SubDyn reaction joint. You can include that stiffness matrix in SoilDyn (as you are doing) or you can include the stiffness matrix in SubDyn directly. Maybe you want to start using SubDyn-only to ensure that your system is stable and add complexity later on. For reference, during the OC6 phase II project I used both approaches (SubDyn-only and SubDyn+SoilDyn CalcOption 1) and both approaches returned the exact same behavior (as expected). Below you can see the definition used for OC6 phase II when using the SubDyn-only approach. This stiffness matrix corresponds to the one shown in the section 3.3.1 that I commented before.
Roger
Dear Roger,
Thank you for the shared information. I already tested for different range of stiffnesses but the result is always the same, even using the values you shared.
The WTG is with 100 m rotor diameter and 95 m hub high. I’m testing with a simple wind flow by using steady wind type with 8 m/s of wind speed (InflowWind).
Once the model starts I receive always this message for the nodal output. I don’t think this is related with the problem, but in any case I just would like to mention this to you.
Could be something related with the WTG configuration defined in the ElastoDyn?
I tested different coordinates for the note 2 in SubDyn and SoilDyn, but without any changes on the results. Below you can find a sketch of the WTG and foundation.
Thank you.
Mário
It’s quite surprising to me… I’m not sure if the issue that you are having is related to SubDyn/SoilDyn or with your numerical model somewhere else. Btw, the message about nodal outputs is normal. It’s just informing you that you didn’t provide information for the nodal output section (i.e., advanced sensors that only some users request).
I’m wondering if your model is working as expected when you use SubDyn with a clamp condition at the base reaction joint?
If I would be you, I would increase the complexity in the model one step at a time. I would not move to the next step (increase complexity) if things are not looking as expected. These are the steps that I would follow:
- Run the model with ElastoDyn (no SubDyn and no SoilDyn). Is the system working as expected? Does the bending moment at the bottom look good?
- Run the model including SubDyn with a clamp at the base. You should get equivalent results to point (1).
- Run the model with SubDyn. Remove the clamp and include a stiffness matrix in the diagonal terms that is quite stiff (not too stiff because otherwise the system will become ill-conditioned). With these settings you should reproduce the results from points (1) and (2).
- Run the model with SubDyn. Define the bending stiffness desired for the Y direction. Is the system rotating as expected? With the bending moment obtained in points (1-2-3) and the bending stiffness, you can anticipate how much the system should rotate at the base (approx. value)
- Run the model with SubDyn and SoilDyn. Remove the bending stiffness in SubDyn and include it in SoilDyn CAlcOption 1. This should return the exact same results as (4).
- Run the model with SubDyn and SoilDyn. Switch from SoilDyn CalcOption 1 to 2 and define a nonlinear stiffness.
Roger
Dear Roger,
Thank you for the inputs.
I’ve been testing from the simplest scenario and adding complexity to the system.
However, I cannot move from the point number (2). When I include the SubDyn with a clamp at the base and releasing all the DoF’s in the platform (ElastoDyn) I get the error as shown below. The only way to move forward is to restrict some of the DoF’s in the platform, but the outcome of the simulation is not realistic, as shown before.
The SubDyn input file includes the following:
-------------------------- SIMULATION CONTROL ---------------------------------
False Echo - Echo input data to "<rootname>.SD.ech" (flag)
"DEFAULT" SDdeltaT - Local Integration Step. If "default", the glue-code integration step will be used.
3 IntMethod - Integration Method [1/2/3/4 = RK4/AB4/ABM4/AM2].
True SttcSolve - Solve dynamics about static equilibrium point
True GuyanLoadCorrection - Include extra moment from lever arm at interface in interface reactions. R. Bergua: This accounts for the gravity being applied over the deflected structure.
-------------------- FEA and CRAIG-BAMPTON PARAMETERS---------------------------
3 FEMMod - FEM switch: element model in the FEM. [1= Euler-Bernoulli(E-B); 2=Tapered E-B (unavailable); 3= 2-node Timoshenko; 4= 2-node tapered Timoshenko (unavailable)]
1 NDiv - Number of sub-elements per member
True CBMod - [T/F] If True perform C-B reduction, else full FEM dofs will be retained. If True, select Nmodes to retain in C-B reduced system.
0 Nmodes - Number of internal modes to retain (ignored if CBMod=False). If Nmodes=0 --> Guyan Reduction.
1 JDampings - Damping Ratios for each retained mode (% of critical) If Nmodes>0, list Nmodes structural damping ratios for each retained mode (% of critical), or a single damping ratio to be applied to all retained modes. (last entered value will be used for all remaining modes).
0 GuyanDampMod - Guyan damping [0=none, 1=Rayleigh Damping, 2= user specified 6x6 matrix]
0, 0 RayleighDamp - Mass and stiffness proportional damping coefficients (Rayleigh Damping) [only if GuyanDampMod=1]
6 GuyanDampSize - Guyan damping matrix (6x6) [only if GuyanDampMod=2]. Roger comment: Damping matrix applied at the Transition Piece.
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
---- STRUCTURE JOINTS: joints connect structure members (~Hydrodyn Input File)---
2 NJoints - Number of joints (-). Roger comments: JointType: (1): cantilever beam, (2) universal joint, (3) revolute joint, (4) spherical joint.
JointID JointXss JointYss JointZss JointType JointDirX JointDirY JointDirZ JointStiff JointDamp ![Coordinates of Member joints in SS-Coordinate System]
(-) (m) (m) (m) (-) (-) (-) (-) (Nm/rad) (N/rad.s)
1 0 0 0 1 0 0 0 0 0
2 0 0 -0.2 1 0 0 0 0 0 ! Revolute joint
------------------- BASE REACTION JOINTS: 1/0 for Locked/Free DOF @ each Reaction Node ---------------------
1 NReact - Number of Joints with reaction forces; be sure to remove all rigid motion DOFs of the structure (else det([K])=[0])
RJointID RctTDXss RctTDYss RctTDZss RctRDXss RctRDYss RctRDZss SSIfile ![Global Coordinate System]
(-) (flag) (flag) (flag) (flag) (flag) (flag) (string)
2 1 1 1 1 1 1
------- INTERFACE JOINTS: 1/0 for Locked (to the TP)/Free DOF @each Interface Joint (only Locked-to-TP implemented thus far (=rigid TP)) ---------
1 NInterf - Number of interface joints locked to the Transition Piece (TP): be sure to remove all rigid motion dofs
IJointID ItfTDXss ItfTDYss ItfTDZss ItfRDXss ItfRDYss ItfRDZss
1 1 1 1 1 1 1
----------------------------------- MEMBERS --------------------------------------
1 NMembers - Number of frame members.
MemberID MJointID1 MJointID2 MPropSetID1 MPropSetID2 MType COSMID Roger comments: MType: (1): beam, (2) pre-tensioned cable, (3) rigid connection.
1 1 2 1 1 1
------------------ MEMBER X-SECTION PROPERTY data 1/2 [isotropic material for now: use this table for circular-tubular elements] ------------------------
1 NPropSets - Number of structurally unique x-sections
PropSetID YoungE ShearG MatDens XsecD XsecT
(-) (N/m2) (N/m2) (kg/m3) (m) (m)
1 4.2E10 1.75E10 1375 5.1 0
Considering only the ElastoDyn with the DoF’s fixed at the platform I get consistent results without any error, as shown by the plot below:
In my view, for some reason, SubDyn is not connecting properly with ElastoDyn at the interface joint.
Thank you.
Mário
It’s good to know that the issue is coming from the beam introduced in SubDyn.
I’m wondering if you are using a model available in a public GitHub repository. If so, I could try adding the beam in SubDyn and figuring out what is going on.
Clearly, your model goes numerically unstable when including the small beam in SubDyn. Some things that you can try to avoid this instability are:
- Reduce the time step in OpenFAST.
- Include 1 correction iteration in OpenFAST input file.
- Include a damping for the beam that you are introducing. For example: RayleighDamp = 0, 0.0106. This would be a Rayleigh stiffness proportional only damping providing 1% critical damping at the frequency of 0.3 Hz and growing linearly for higher frequencies.
- In SubDyn note that XsecT is the beam thickness. I understand that you are trying to define a solid beam?
- The beam introduced in SubDyn seems to be very short (0.2 m) and wide (5.1 m in diameter). I expect this to result in a very high frequency for this SubDyn part (this frequency can be checked in the SubDyn summary file, *.yaml extension: look for “Frequencies of Guyan modes”). This could challenge the ElastoDyn-SubDyn coupling requiring quite small time steps. Actually, a message should be printed in the console when running OpenFAST about this frequency and a recommended time step.
- I do not expect this short and stiff beam to change the dynamics in your system much. However, note that if the dynamics change (e.g., introducing some compliance at the bottom like a stiffness matrix at the seabed), you should compute again the mode shapes for the tower according to the new boundary conditions. ElastoDyn relies in a assumed modes approach where the user must provide the tower mode shapes as input.
I hope that helps!
Roger
Dear Roger,
I believe I was able to understand what I was doing wrong, by reading your point number 4. I was not paying attention to the MEMBER SECTION PROPERTY. For now, by changing the dimensions of XsecD and XsecT the model was able to run, even considering the REDWIN DLL model 1, with results that seems to be in line with the expected.
Once again, thank you for your precious inputs. I hope not need to bother you again with this topic
Thank you and best regards,
Mário
Hello everyone,
I modeled the (soil domain and monopile) in ABAQUS as a superelement and I run the analysis as Pseudo-static analysis ( I applied the maximum base moment from OpenFast and the corressponding shear force) and I get the nonlinear stiffness matrix 66 at the retained node at the seabed. Now, I want to insert this nonlinear 66 stiffness matrix in OpenFast. I searched in the current branch of SoilDyn in the following PR SoilDyn -- soil dynamics module by andrew-platt · Pull Request #986 · OpenFAST/openfast · GitHub, but I couldn’t find the SoilDyn input file. But here in this post, I found that Roger Bergua kindly posted the input file. My questions are
1- Should I change the source code to account for SoilDyn? or how to use this input file?
2- Is this the latest source code that I should change openfast/modules/soildyn/src/SoilDyn.f90 at f/SoilDyn · andrew-platt/openfast · GitHub ?
3- If I used ( CalcOption = 1) in this case, Will SoilDyn consider the nonlinearity or it will treat it as linear and I should use ( CalcOption =3)?
4- My 6*6 stiffness matrix from ABAQUS model is fully populated , why in REDWIN Macro-element Model there is many off diagonals with zeros? is my stiffness matrix incorrect?
Any comments are appreciated
Marwa
Thanks Dr. Jason for your reply.
3- Do you mean that (CalcOption =1) is the same as adding linear stiffness matrix through SSI in SubDyn and the only difference is the damping matrix? another question please, I understand that the nonlinear response is combination of the linear part (which independent of the load level) in addition to the nonlinear part (which depend on the applied load). But how to get this from ABAQUS? I already have nonlinear stiffness matrix from model (considering material and geometric nonlinearity) and I got the linear stiffness matrix from the same model ( but assume that material is linear elastic and linear small response). Should I just subtract the linear matrix from nonlinear matrix to get the nonlinear part in SoilDyn and keep the linear matrix in the SubDynor it’s wrong?
4-
I mean why in this matrix there is zeros term and my matrix is fully populated. According to ABAQUS theory that the stiffness amtrix for the Superelement is fully populated ( no zeros ) as the Superelement is an exact representation of its memeber and there is no approximation. Is my matrix wrong?
Marwa
the attached figure from “Specification Document for OC6 Phase II: Verification of an Advanced Soil Structure Interaction Model for Offshore Wind Turbines” Roger Bergua, Amy Robertson, Jason Jonkman, and Andy Platt. 2021
Dear @Marwa.Mohamed,
I would expect your stiffness matrix to be -mainly- uncoupled for the vertical and torsional directions. This means that the terms K31, K32, K34, K35, K36 and K61, K62, K63, K64, K65 should be relatively small or zero. Otherwise, it would mean that when applying a load on those directions (i.e., vertical or torsional), there is a secondary direction also playing a role. Since you are using a FEM approach, there may be some influences between directions due to the mesh not being perfect (e.g., axisymmetric) or some numerical errors. But, as commented, the magnitudes that you find in those directions should be relatively small. Feel free to provide the stiffness matrix that you are working with and we can tell you if it makes physical sense or not.
Note that the expected cross-coupling coefficients between horizontal and rotational DOFs are explained in the OC6 phase II definition document. For example, when applying a load along the x-axis (e.g., longitudinal load), you expect to see a displacement along the x direction and one rotation around the y-axis. You don’t expect to see a displacement in the y direction (e.g., lateral) or a rotation around the x-axis (e.g., perpendicular bending) or a rotation around the vertical axis (torsion). That’s why those coefficients are zero.
I hope this helps!
I agree with @Roger.Bergua’s response to (4).
Regarding (3), I fully agree with your response.
