Hello!
I am trying to obtain the EXE file by building it from the source code. The end goal is to be able to get a version with a modified IfW_UserWind.f90.
I have all the prerequisites specified on the site. After cloning the repository, I am following those steps in the Intel Command prompt:
mkdir build
cd build
cmake .. -G “Visual Studio 17 2022” -A x64 -DBUILD_SHARED_LIBS=ON -DCMAKE_BUILD_TYPE=Release
cmake --build . --config Release
2. Installing OpenFAST — OpenFAST v4.1.2 documentation says that the result should be in openfast/build/glue-codes/Release/openfast.exe, but the Release folder is empty for me.
Am I missing a step? How can I obtain the EXE file?
Bets regards,
Tudor
When I tried to run the provided commands, the configure and build failed. Typically, Windows users open the solution at vs-build\FAST\FAST.sln with Visual Studio instead of working with CMake, so the other options aren’t as well tested. I recommend using that solution for project development.
If you want to continue with CMake, I just tested the following commands and verified that they generate an OpenFAST executable at build\glue-codes\openfast\openfast.exe.
cmake .. -G “Ninja” -DBUILD_SHARED_LIBS=OFF -DCMAKE_BUILD_TYPE=Release
cmake --build .
This doesn’t work with BUILD_SHARED_LIBS=ON, can you explain why you’re using this option. Also, please include the output of the commands, especially if they include error messages.
Derek Slaughter
Dear Derek,
I tried the lines you recommended, and I got a working openfast.exe.
Thank you for your answer!
Tudor Istrate
