Tower distributed properties is as follows ;
[attachment=0]Tower.pdf[/attachment]
Dear Arasalan,
I don’t see anything obviously wrong from my brief review of your files. But I can’t run the models myself when they are in PDF format. Can you upload the files in text format? (Change the file extension to .txt if you need to.)
I have trouble with uploading .txt files and receive " http error " when uploading the files with .txt format. What should I do ?
I haved zipped the files so that I could upload them and they are as follows;
subdyn.zip (214 Bytes)
Driver.zip (904 Bytes)
BModes.txt.zip (998 Bytes)
Furthermore, the Tower distributed properties file is sent by next post because of post size limit.
Dear Arsalan,
I was able to obtain the Tower.txt and Driver.txt files from your uploaded archives, but the SubDyn.zip and BModes.txt.zip archives seem to be corrupted and I cannot extract the text files. Can you simply upload these text files directly?
As I said it seems the forum has a size limit for the .txt format files. Therefore, I ought to send them as compressed version.
I repaired the corrupted files and uploaded them again which are as follows;
subdyn.rar (3.97 KB)
BModes.txt.rar (2.86 KB)
Dear Arsalan,
OK, I was able to extract BModes.txt and SubDyn.txt this time and I mimicked your problem with BModes. I found that the problem was a simple error in the input file, which I had missed in my earlier review. BModes input tow_support must be set to 1 for it it use the remaining inputs in the tower support system properties section of the BModes input file (tow_support=0 is really for modeling a simple free-free beam, without tower-base restraints). Setting tow_support=1 produces the expected results.
Yes I could manage it successfully.
I really appreciate you as always.
