lift cofficient partial derivative about attack angle
Dear Wenhua,
Your approach sounds reasonable, so, I’m not sure why your results are not as you expect. The slope of the linear region of the lift curve (near zero degrees angle of attack) should be easy to estimate by hand; how does your solution compare with the results published in the literature in the linear region of the curve?
