Thanks for the reply.
I tried to make the changes you suggested, however these have not yet solved the problem.
Nonlinear inertial terms (Figure 1), i.e., omega x (omega x r_cm * mass) and omega x I dot omega have little effect (around 5 N or 5Nm for each force / moment except Fz where there are peaks of 800N). Can you confirm that omega = [rxd, ryd, rzd]?
I tried to multiply the accelerations obtained by FAST by the mass matrix M, obtaining the resulting forces acting in the 6dof (Figure 2): as you can see it takes moments on Mx and Mz of order 10 ^ 4, I can’t understand how they are caused since non-linear terms have such a low incidence.
I modified the mass matrix, translating it for each timestep in relation to the movements of the platform:
I obtained the mass matrix relative to the center of mass through the following inverse transformation: Mcg = (TransMat^T)^-1 * M_swl * TransMat^-1 (where TransMat is the one indicated in this topic "OC3-Hywind RAOs where the inputs of the rotation matrix are those in still water). Then the mass matrix (in 0 0 0) relative to the position of the system is obtained by applying the direct transformation M_swl = TransMat^T * Mcg * TransMat, using the current positions of Cg as the input of TransMat.
Even with this change there are no improvements, Mx and Mz of my model still remain too low.
Riccardo
