hello,Jason
I have two serious problems about FAST and MExtremes.
First,I used the FASTv7 recompiled with my bladed-dll to run the IEC dlc,I found the output variables pitch angles (PtchPmzc1,PtchPmzc2,PtchPmzc3)are different. I am sure the the demand angles from dll is right and same.But when I use the first order transfer function as the ptich auctor (Y=alpha*DemandPitch+(1-alpha)*MeasuredPitch),if the alpha=1,the result is normal,if not 1,the three variables ( PtchPmzc1,PtchPmzc2,PtchPmzc3)sometimes become different and illed like below :
I can not find out why the pitch angles are different and illed.
Second,When I finished the IEC dlc,I use the MExtreme to make a statistics, There are thousands of cases to deal with.I set the
NumDLCS to 7, some error happend when from the first DLCs to second DLCs like below:
I have upload the .mext file in the attachments.
Hope your guides
Best Regard!
Ruiliang.Wang
mext.xlsx (40.2 KB)
