Dear Sirs,
I’ve Just compiled FAST in Debug Configuration for looking how the code works. Without noticing I checked the option ‘Check Array and Strind Bounds’ and I got a running Error.
I’ve used the Test01 files. The Error is triggered when calling to MakeADM_WrlCArrays in line 3987. The line reads as:
CALL MakeADM_WrICArrays ( IDCntrl(:,K), IDCntrl_A(K) , BldNodes, UnAD, “IDCntrl_A”//TRIM(Int2LStr(K)) )
The problem is that IDCntrl(:,1) has 2 values, and BldNodes = 10.
When running without the ckeck bounds gives no error and everything seems to go Ok.
The question is: Is this the intended way of working? Is there anything wrong in the call in line 3987?
Thanks in advance, best regards from:
Diego Peinado.
