Campbell diagram for 5MW turbine rotor
I just reviewed your derived Campbell diagram for the land-based 5 MW baseline wind turbine. It was in your post from Thu Sep 22, 2016 8:24 am.
Furthermore I reviewed the tower section 6 in Jonkman, J., Butterfield, S., Musial, W., and Scott, G: Definition of a 5-MW Reference Wind Turbine for Offshore System Development. February 2009.
In this section 6 on page 15 in the second paragraph, one writes:
This sounds like the wall thickness of the baseline tower is driven by its first two eigenfrequencies. But when I go back to your Campbell diagram I see, that these tower eigenfrequencies are very close to the three-per-rev frequencie at cut-in rotational speed. In fact, neglecting the proposed wall thickness increasement of 30 % would decrease the tower eigenfrequencies to about 0.282 Hz and a larger distance to the exciting three-per-rev frequency can be obtained. Note, that it would still have enough distance to the one-per-rev excitation frequency of 12.1 1/min / 60 s/min * 1.05 = 0.21 Hz.
What do you think about this?
Achim
Dear Achim,
What you say sounds reasonable.
If I recall correctly (although this was over 10 years ago now), I think the cut-in speed dropped a bit over the course of the NREL 5-MW development and perhaps the tower thickness was set before this and not later updated.
I agree that the final first tower fore-aft and side-to-side mode frequencies are bit close to the 3P frequency at the cut-in rotor speed. That said, I don’t recall finding a problem with resonance of the tower from 3P excitation.
I need some clarification with the Campbell diagram (Excel file) of the land-based NREL 5-MW turbine that you posted here (Campbell diagram for 5MW turbine rotor) in the forum on Sep 22, 2016. I think that the values for the 2nd blade regressive and progressive modes in rows 14 and 16 in the “CampbellDiagram” worksheet are reversed. Based on the data (natural frequencies) for the 1st blade flapwise regressive and progressive modes (6th and 8th row) on the CambellDigram worksheet, I understand that data corresponding to the 1st blade regressive and progressive modes was chosen from the rows 20 and 19 of the worksheets with names 0 RPM to 14 RPM. Likewise, the 1st blade edgewise regressive and progressive data was chosen from the rows 23 and 22 respectively. However, the reverse was done for 2nd flapwise regressive and progressive modes i.e. data from rows 25 and 26 are chosen for regressive and progressive modes shown in the rows 14 and 16 on the CambellDigram worksheet. Was this a mistake or do you have any particular explanation for doing this for only the 2nd blade regressive and progressive modes?
Srinivasa
Dear Srinivasa,
This is simply a naming convention. By “regressive”, I mean the asymmetric mode that reduces in frequency with increasing rotor speed. By “progressive”, I mean the asymmetric mode that increases in frequency with increasing rotor speed.
Thanks for the clarification.
Srinivasa
I am trying to recreate your campbell diagram .xls for the 5MW land turbine to understand the process of linearization. Unfortunately I am not making any fast progress. Would you be willing to sent me your input files to recreate the diagram so I can study them and understand the process?
Thank you very much,
best regards, Veith
Dear @Veith.Hieber,
This forum topic is now quite old, and the original Campbell diagram of the land-based NREL 5-MW baseline wind turbine is now over 10 years old. I’m not sure where the complete set of input/output files are (or even if they still exist), however, at least the FAST v7 files for the case at zero rpm is available through the workshop materials that are still available. My original reply refers to the FAST workshop at EWAE Offshore in Frankfurt, whose materials you can find here: WindTurbineModelingWorkshop_131120_EWEAOffshore_FrankfurtGermany - Google Drive. Much more recent OpenFAST workshop materials are available from: OpenFASTWorkshop_231102_NAWEA_BroomfieldCO - Google Drive.
thank you, the workshop material helped quite a lot. I have now created a Campbell diagram for the 5 MW off-shore wind turbine. Ive plotted the natural frequencies in relation to the wind speed in m/s. Now I am stuck to generate the excitation frequency as a function of wind
speed for 1P, 3P, 6P etc., do you have any suggestions?
Im also not to sure about my frequencies of the 2nd tower FA and the 2nd Blade Flap (progressive) - Ive attached my Campbell to visualize my problem, from the point of 13 mps on wards Ive added the relative pitch angle. I dont think this would cause the problem tough?
best regards,
Dear @Veith.Hieber,
Just a few comments:
  • Regarding your Campbell diagrams, there are a couple “jumps” between 9 and 13 m/s, which I assume is just incorrect labeling of the modes.
  • When computing Campbell diagrams as a function of wind speed, it is important to ensure that your rotor speed and blade-pitch angles are set appropriately at each wind speed; have you verified those?
  • The 1P, 3P, 6P, etc. excitation frequencies are just plots of the rotor speed (and their harmonics) converted from rpm to Hz as a function of wind speed.
