NREL 5-MW reference turbine - CP, CQ, CT Coefficients
Ok, I understand that, thank you very much for your help.
Rocío
Hello again,
I’ve been working on NREL-5MW wind turbine and there is something bugging me. This turbine is rated at wind speed = 11.4m/s and TSR = 7 (as stated here: nrel.gov/docs/fy09osti/38060.pdf) for 5MW of power. Examining the document and assuming this is an offshore wind turbine, considering the air density as 1.225 kg/m^3, Cp at design conditions is 0.44. When I observe in Mr. Jonkman and Mr. Chaaban’s results, higher Cp is achieved at even lower wind speeds. I am also getting higher values using RANS-ALM methodology. Now I might be wrong but AeroDyn and FAST are used to obtain results in that document. I am not sure what I’m missing in the consistency here. I am also having a hard time finding reliable experimental or numerical results on this turbine in journals or papers.
Some data I have found:
iopscience.iop.org/article/10.10 … 082003/pdf
brage.bibsys.no/xmlui/bitstream … sAllowed=y (this paper also refers to this forum)
Other sources you might come across would be extremely valuable, as well as your ideas on the matter I’ve mentioned.
Hüseyin
Dear Hüseyin,
I’m not sure I understand your concern, but I would expect a maximum aerodynamic Cp of the NREL 5-MW wind turbine to be around 0.48 in region 2 using blade-element/momentum (BEM) theory. Of course, some power is lost in the mechanical-to-electrical conversion (generator efficiency), so, the effective electrical Cp would be less.
I computed the thrust coefficient vs wind speed with the stand alone Aerodyn V15.
The results are shown below.
Does the results seem coherent?
Thank you.
Etienne JARGOT
Dear Etienne,
Yes, your results look like what I would expect for the NREL 5-MW turbine.
In the post I am citing bellow, Rannam Chaaban asked you about the values to set for parameters in SIMPLE VARIABLE-SPEED TORQUE CONTROL.
As you answered in your reply, I would also expect to give VS_Rgn2K a value of 0.0255764 and VS_SlPc a value of 10.
Nevertheless, I do not understand why should VS_RtGnSp be the 99% of rated HSS speed.
As far as I understand, that point (wGen = 1162 rpm) in the torque curve corresponds to a higher torque value (43528.84 Nm). This was recently discussed in the following post: [url]NREL 5MW Torque vs GenSpeed Curve Points - #3 by Jon.Martinez].
Therefore, I would expect VS_RtGnSp to be the rated generator speed: 1173.7 rpm, which would correspond to the rated torque of 43093.55 Nm.
Here I put a summary of the values that I would expect:
---------------------- SIMPLE VARIABLE-SPEED TORQUE CONTROL --------------------
1173.7 VS_RtGnSp
43093.55 VS_RtTq
0.0255764 VS_Rgn2K
10 VS_SlPc
Are these values OK?
Thank you in advance,
Jon Martínez Rico
Dear Jon,
The simple variable-speed controller in the ServoDyn module of FAST v8 or OpenFAST cannot fully represent the characteristics of the baseline NREL 5-MW turque speed curve. This is because the simple variable-speed controller does not include Regions 1 and 1.5 and because Region 3 is considered using constant torque, rather than the constant power used in the NREL 5-MW baseline controller. I had recommend setting VS_RtGnSp equal to 99% of the actual rated speed of 1173.7 to ensure that the synchronous speed for Region 2.5 (i.e., 0.99*1173.7/(1+0.1) = 1056.33 rpm) was identical in both models. Also setting the rated speed right at the transition speeds between Regions 2.5 and 3 tends to cause problems in the blade-pitch controller.
Thank you very much for your anserwer.
Jon Martínez Rico
I have some doubts about thrust of NREL 5MW given in this article [Definition-of-a-5-MW-reference-wind-turbine-for-offshore-system-development](Figure 9-1. Steady-state responses as a function of wind speed).
I used ORIGIN to obtain the data of RotThrust vs wind speed, and then it was easy to get the CT(coefficient of thrust, the black line) with the formula(air density=1.225, Ad=3.1415*63^2)
At the same time, I used FAST to calculate Ct in different average wind speed ranged from 3-25 m/s(the red line).
The strange things is that those 2 line has huge difference. Why has this happened? Is it normal Ct is as high as 2.5?
Chenxu.Zhao
Dear Chenxu.Zhao,
The FAST (ElastoDyn) output RotThrust is the reaction force transmitted from the rotor to the shaft, so, not only includes the applied aerodynamic forces, but also the forces resulting from rotor weight (and in transient analysis, rotor inertia); see related forum posts on this topic. So, normally, RotThrust is shifted upward relative to the aerodynamic applied Thrust. If you are using AeroDyn v15, you can output the aerodynamic applied rotor thrust via AeroDyn output RtAeroFxh.
Thank you so much for your answer, sir! That had really solved most of my confusions.
But there is still one little problem. The red line was exactly caculated by using your method of getting ‘RtAeroFxh’ from FAST. And still when wind velocity equals 3m/s, the CT is somewhat higher than 1 as 1.1 . If this is the right way to do it, then what’s the reason for this abnormal phenomenum? From the textbooks I have read, they told me that CT was not allowed to be more than 1.
Chenxu.Zhao
Dear Chenxu,
Actually, the aerodynamic thrust is able to exceed 1, but in this situation, flow will recirculate around the rotor and momentum theory no longer applies. At high thrust, AeroDyn uses Glauert’s empirical correction with Buhl’s modification in place of momentum theory.
Thanks again! It turns out I need to do more researches about the theories used by FAST. Your guidence is really useful to me.
Chenxu.Zhao
Hi, everyone
I have some problems with the output parameters, “B1N1DynP”, “B1N1Fx” and “B1N1Fy”. Based on the “OutListParameters.excel” in the archive of FAST V8, I know the “B1N1Fx” and “B1N1Fy” refer to the normal and tangential forces to plane per unit length for Node 1 of Blade 1, and “B1N1DynP” means the dynamic pressure for Node 1 of Blade 1. If I want to employ these output parameters in my finite element model as the wind loading, How could I utilize these parameters? I have some ideas based on the attached figure, but I do not know whether it is right.
If I employ the parameters “B1N1Fx” and “B1N1Fy”, I prefer to adopt two methods:
  1. assuming only the forces per unit length at the nodes are accurate, the centering normal force at Node 3 could be calculated by B1N3Fx*(L2+L3)/2
  2. assuming the forces along the blade could be linearly interpolated, the concentrated force at Node 3 should be computed by ((B1N2Fx+B1N3Fx)/2+B1N3Fx)/2L2/2+((B1N3Fx+B1N4Fx)/2+B1N3Fx)/2L3/2
If I adopt the parameter “B1N1DynP”, How should I do?
Any hints would be much appreciated.
Jian
Dear Jian,
Are you referring to AeroDyn outputs? These are the aerodynamic applied loads per unit length along the blade.
I’m not sure I really understand your question, but if your FE model accepts applied forces per unit length, but the nodes are not co-located with the AeroDyn nodes, then, yes, you could interpolate the AeroDyn outputs before using them in your FE model.
Thank you for your timely response.
Yes, I refer to the AeroDyn outputs. I just edited my questions for clarity. I wonder if I want to impose the concentrated force on the blade, whether the method I mentioned is right? I am still confused about how to employ the parameter “B1N1DynP”, could you give me more clues. Thank you.
Jian
Dear Jian,
I think methods (1) and (2) will give very comparable results, especially as the element lengths decrease. We use a slightly different method in the internal Line2-to-Point mesh-to-mesh mapping in the FAST modularization framework (that also ensures that the overall moments balance between the two meshes), but again, I would guess the results would be very comparable as the element lengths decrease. You can read about the mesh-to-mesh mapping inherent within FAST in the attached paper.
Sprauge_Jonkman_Jonkman_FASTModularFrameworkForWindTurbineSimulation-NewAlgorithmsAndNumericalExamples_AIAA_2015.pdf (498 KB)
The dynamic pressure is defined such that:
B1N1Fx = B1N1CxB1N1DynPBlChord
I tried to implement a BEM code in MATLAB, using the Distributed Blade Aerodynamic Properties of the 5MW NREL wind turbine (Table 3-1 in the 5MW NREL reference pdf: nrel.gov/docs/fy09osti/38060.pdf) and the airfoils data. I find the maximum power coefficient of Cp_max=0.486 at TSR=7.82 and Pitch=0.0°, which are slightly off what is in the pdf reference (Cp_max=0.482 and TSR=7.55). Here is a plot of Cp with TSR and Pitch angle.
I have two questions:
_ Is this tiny difference comes from the number of blade nodes taken?
_ Are those results that I found make sense to you?
Dear Younes,
Yes, these results are quite similar to the ones generated by NREL. Differences could be the result of discretization (which could easily checked by studying the convergence with increasing number of nodes) or by differences in the underlying BEM assumptions (more difficult to assess).
Thank you so much for the reply. I am wondering if there is a Cp table for the 5MW NREL wind turbine that we can use, or should we compute it ourselves? I see that WT_Perf is not available anymore.
Kindest regards
Younes
