Dear Dr Jonkman,
Could you please send me the “Unofficial FAST Theory Manual” as well?
fanzhong.meng12@googlemail.com
Thank you,
Kind regards
Fanzhong
Dear Dr Jonkman,
Thank you,
Kind regards
Fanzhong
Sent.
Dear Mr Jonkman,
Can you please send me the “Unofficial FAST Theory Manual” as well?
Thank you,
Achour.A
Sent.
could you please send me the unofficial theory manual?
My email is luca.greco@cnr.it
Thanks a lot.
Luca
Sent.
Could you please send me the unofficial theory manual?
Email : farhadabtahi91@gmail.com
farhad
Sent.
I would appreciate if you could also send me the theory manual?
Email: altay@lbb.rwth-aachen.de
Thank you in advance!
Okyay
Sent.
Dear Dr. Jonkman,
In FAST are centrifugal stiffening effect and gravitational stiffening/softening effect added separated? Or does it come inherently from the formulation?
Saptarshi
Dear Saptarshi,
I’m not sure what you mean when you say, “effect added separated”. Regardless, though, the gravitational softening and centrifugal stiffening are inherent in the structural-dynamics formulation.
Could you please send me the theory manual?
Email : hmzxyk@hotmail.com
Yining.Chen
Sent.
Email : xirenqiang@cczu.edu.cn
Renqiang.Xi
Sent.
Dear Dr. Jonkman,
I’m trying to match the modal frequencies of my model to that of FAST. For the 1st mode (both tower and blade flapwise) my frequencies are matching. But, for the second mode (again both tower and blade flapwise) my modal frequencies are less compared to that of FAST. For example, from FAST 2nd flapwsie modal frequency is around 1.92Hz while from my model it is 1.56Hz.
I’m using the same procedure of multiplying the derivatives of mode shapes with sectional stiffness and integrating. The same procedure gives me correct frequencies for the 1st modes but not for the second modes.
So, I guess my question is, is there any modal participation factor involved? If so, how should I calculate it? If not, what else can be wrong in my model?
Thank you so much for replying to all my previous question.
Thank you,
Saptarshi
Dear Saptarshi,
I don’t think I know enough about what you’ve done to comment. How are you extracting natural frequencies out of your FAST model? How are you extracting natural frequencies out of your model?
Dear Dr. Jonkman,
From FAST I’ve used the linearization analysis to calculate the natural frequencies.
From my model, I’m just using the elastic stiffness and the modal mass to calculate the frequency.
Now I understand that the stiffness from FAST linearization will be higher/lower due to centrifugal stiffening and gravity effects. But, I expect that variation to be 1.92(±0.1)Hz. But the difference I’m getting is about 0.4Hz which I think should come from the elastic stiffness.
I’m also getting a difference of almost 1Hz for tower 2nd mode.
I hope you understand what I’m saying.
Thank you again,
Saptarshi
I would love it if you sent me the theory manual, would this be possible?
Email : jonisak@student.chalmers.se
//Jonatan
